Salta al contenuto principale
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 Domande Visualizza tutte
horizontal line across screen.
Vizio E5001 HDTV. Picture has horizontal line across screen. Lower screen appears to be slightly out of focus. Narrow strip across top of screen looks to be bottom of picture.
Is this an adjustment problem of hardware issue?
Questa è una buona domanda?
Punteggio 14
5 Commenti
Could be TAB (would most likely require a new LCD) as well as a t-con board issue. Post an image with your question so we can see what you see.
da
I have 2 Vizo Tvs Both went out in 2 years period . I would love y
Too have them fixed but paid a lot for them 65in and a 45in Went back too store to see what kind of Warrenty they had none ...and 2 years and Over 2,000 Gone...
da
I insured my Vizio E-series 50 inch 3D TV for $8. When mine went, They replaced my TV with a Samsung HDTV. There were NO Vizio 3D TVs available, and other 3D TVs were $1800 dollars MORE for 3D. They said: "You can do whatever you want with the broken TV. I kept it. I have now done all the research, and have purchased the necessary parts. I will now FIX that puppy.
da
Just got a Vizio 55" smart tv have had it less then a week and lines through the picture when using YouTube. They stay even when I back out to regular tv and have to shut off tv to get rid if them.
da
I'm having a similar issue with a vizio sv470m. When I go to turn it on, the tv will have horizontal lines. Eventually it ends up working correctly. I just play with the buttons or unplug the power for certain amounts of time. After I get the tv working, as long as its on there are no issues with it whatsoever. Now if these simple methods don't work, ive heard it may be issue with the ribbon that connects between the board to the screen and the other board. I'm not being specific because on my model it look like the display board goes to the power board. I'm guessing its both the tcon and power board.
da
Aggiungi un commento
14 Risposte
Risposta Più Utile
Wow these are some misleading amature Repair answer on this forum. Unless you are a certified tech or have many years actaully Repairs not replacing parts, shouldn't answer. I do motherboard work and I've never had a tv issue that isn't fixable . the only way I've ever replaced the whole LCD Screen itself is if it's completly shattered. I then still pull it apart , =Repair any damages backlights , resolder chips, replace ribbions and etc. Finding a compatible front glass of the layers of the screen can get tricky but it's all just a matter of proper research , self confidence and dedication. If not tech savy with a solder gun or ever messed with a board have a tech savvy buddy lend a ✋ . ///dpluda563@***gmail///.\\\com\\\ all one word no symbols I use to avoid spam . need help feel free to message I'll do best to lead you in the right direction.
Punteggio 1
2 Commenti:
I'm in need of some help what's the steps and binding compatible LED screen for a Vizio e70 E3
da
My TV has several horizontal lines and the picture struggles to come into focus , but I've found that it's only when tv is cold. Something has warped a bit from being on constantly for thousands of hours. After 5 or so minutes it warms up and picture is fine. You can actually see it getting better as time progresses. If this happens when you turn it on, wait a half hour and see. I just keep it on constantly but when theres a storm and power fails for more than 30 minutes or I forget to turn it back on after, only time it happens. Actually waiting for it now.
Same issue here, multi colored blurry image on start up, then settles down after ‘warm up’ approx 5 minutes.
What part needs replacing?
da
If it's a t-con issue, you could order the part from http://vizpartsdirect.com/index1.php and install it yourself to save some money.
Here is the link to their parts sections: http://vizpartsdirect.com/parts.php?belo...
Punteggio 0
11 Commenti:
I have a similar problem it's not a black horizontal line but a darker color line then the rest of picture. I will take picture when I get home and send it.
da
I have a Vizio LED TV 70" Model: M701d-A3
There is a single horizontal line across the screen that shows up in the lower aspect of the screen, extending more than 3/4 of the screen width. The line is black in color, you can see it with all TV inputs and when you pull up the menu it appears over the Menu.
How can I fix it?
da
I have a 42" vizio smart tv and the black horizontal line appears for 2 seconds...then picture gets blurry for 2 seconds..then it keeps repeating itself
da
I have the same issue as Nate. Any fix? Can't afford new TV.
da
I have a 19" vizio and it has a green line across the bottom and it constantly flickering, i have no blurring though, still great picture just the line at very bottom that won't go away. Anybody else experiencing this.
da
Mostra altri 6 commenti
Try switching to a different outlet. I had mine connected to a bad power conditioner (Isobar) box. After I plugged it into a different outlet, it works fine now.
Punteggio 0
The top of the screen is turning dark. About 6" down from top down. Visio 65" smart.
Punteggio 0
Punteggio 0
1 Commento:
Same issue what part needs replacing?
da
hi thats seems to be a screen malfuction, the only possible repair is by changing the screen, i had seen this problem a lot on laptops displays and pc monitors, good luck
Punteggio 0
'''Got a 24” smart tv D24f-F1 model. Got a blackscreen with blurry vertical lines. the only part of the screen that is still visible is the very top of the screen. If i leave it on for several hours sometimes it comes back to focus but i have been curently waiting an hour an 45 minutes for it to come back and still nothing. Any suggestions? I have tried a power cycle with no results and was told to factory reset but cant see the menu :(
Punteggio 0
1 Commento:
[image|1650343] i unpluged it and moved it to a different outlet. It cleared the screen up enough to let me factory reset it. But now there is a black horizontal line across the botom of the screen
da
I have a vizio e65 3c. I'm having horizontal lines on picture that roll from bottom to top. As if the vhold is off on an old school tv. Screen is not broken. All backlights work and replaced tcon and main board. Still having same problem. Please help. Please email me with help. Jakebraswell1328@gmail.com
Punteggio 0
I ended up taking it back and exchanging for a new one same model. After a week I was having the same issues so I took it back again and got a Hisense. I have not had a single issue with the Hisense.
Punteggio 0
I had this problem with lines then dots running horizontally across the middle of the screen. Went to reset and it solved the problem.
Punteggio 0
That wasn't the solution to my problem. Someone had posted a while back, that it was a resistor or something that they had to change out.
Punteggio 0
Yes I have this problem
Punteggio 0
1 Commento:
I need to know what's wrong with my tv
da
If it is an LG or Mitsubishi (supposedly respectable brands) or Westinghouse, Element, etc (the ones placed in displays in the middle of the aisles at most Walmart’s), my recommendation is a 12-gauge Winchester slug to the center.
Punteggio 0
I have a Vizio plasma screen 40 in it has a green line 9 inches long down the top left edge of the screen down how do I get rid of that ? Maybe have it serviced thanks a
Punteggio 0
Aggiungi la tua risposta
silentservice650 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 60
Tutti i Tempi: 91,586
