Salta al contenuto principale
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Domande Visualizza tutte
Domanda Chiusa
What to do about cracked LCD
So I have a cracked LCD. I'm wondering if I can replace the LCD or whole screen assembly using a "for spare parts" macbook air 11" on Ebay (ie the motherboard needs replacing or it has keyboard water damage). I've replaced the motherboard in my old Macbook Pro several times so I think I'd be ok with the actual process.
If not, then I thought perhaps I can rig up an external screen and just go with that. Can I get 11" screens that can just sit in front of current one?
Questa è una buona domanda?
Punteggio 0
3 Commenti
PS it's the price of replacing the screen that's the clincher. I live in Australia and find these things are harder to get at a reasonable price than in the US. Therefore the idea of using a screen from a broken macbook air came to mind, but I don't know if that's possible? As in, if the macbook air was fine except someone spilt water on it, damaged the motherboard etc, would the screen still be fully functional?
da
Is Alibaba trustworthy? I found this: http://www.alibaba.com/product-detail/Co...
da
I've been buying from them for years without any issues. Remember that the vendors are individual under the Alibaba umbrella. Pay with Paypal and you will be safe.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If you've done one you should be able to do this.
If there are newer or additional tools suggested obtain them (every job is easier when you use the correct tools). Study the guide and notes before you begin (not just read them) and keep track of all the screws.
If you no longer need portability you could use an external monitor.
If this answer is acceptable please remember to return and mark it.
Punteggio 2
You may want to talk to these folks as they repair damaged displays: PowerBook Medic - MacBook Air display assembly or these folks OWC - Full LCD Display Assembly
In any case the Apple part is: Display Module 661-6069
You don't want to tackle the LCD replacement it's very difficult!
Punteggio 2
1 Commento:
Thank you it always takes me ages to find those part numbers :)
da
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 156
