Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
Broken home button prong, can I make an alternate?
Ok, so I did a screen replacement on an iphone 5c. This was the second screen replacement on the same phone with in a 2 week time period. Both times phone was dropped. I replaced the screen and tested as much as I could without the pass code. When they got it home and had the pass code available they found everything functional but, the home button. I pulled it back apart and looked over everything and to my horror found one of the metal contact prongs for the home button had broken off. Is there anyway to fix this? Solder on a piece?
Thanks!
Questa è una buona domanda?
Punteggio 1
2 Commenti
Ok, I got it I replaced the whole charge port assemble which it was attached to!
da
Boy do I feel like a noob! I didn't properly understand your question (my fault, reading and repairing at same time is difficult!). I don't know why I suggested a home button flex when the prongs you were talking about were a part of the dock connector. Sorry!
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
The home button flex for the 5c is very cheap and you don't have to worry about the touch ID sensor either, so go ahead and swap out the flex!
Trying to solder on the piece would not be effective, based upon time and cost expenditure compared to a new flex. You could cause more damage, you could possibly spend hours trying to solder it back on properly only to have it fail a week later, or you could just purchase a new flex for under $5 and install it in under 20 minutes.
I do not want to tell you how to proceed but if I were in your position, I would just replace the flex.
Punteggio 2
3 Commenti:
You don't even have to hunt around online for the best deal! You can find it all here on ifixit.
iPhone 5c Home Button Ribbon Cable
da
Hi Eric, I clicked your profile to try and send you a message today--no email listed. I sent you a note through your Device Savers page. Let me know if you got it. (I will delete this comment later).
da
I don't see any messages but I added my email to my about me section.
da
Looks like you got a solution, awesome!
I do a lot of iPhone 5 no home, no power pry damage repair and we have to test the home button function on passcode locked devices, and devices that are not activated. Here are some tricks we've learned:
If you have the device locked, aka sleeping, via the lock/unlock button---then pushing the home button should wake up the phone.
If the device is on iOS 8, and post battery disconnect, so that it is really grumpy for that passcode, you can confirm home button function by doing a hard reset---the power and home button will force the phone to restart when held together for 10 seconds. Both buttons must work for this to happen.
If it is just passcode locked, then flipping up to the camera and then hitting the home button will bring you back to the lock screen.
If it is on the activation wizard after a restore, then click through a few pages. Pushing the home button will bring up a 'cancel/start over/emergency call' dialog.
Punteggio 0
Aggiungi la tua risposta
kerri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,840
