Salta al contenuto principale
Cen-Tech Seven Function Digital Multimeter . Model number 90899.
Why won't the screen show any readout?
I want to use my multimeter to test a battery. The banana plugs are attached and cords are attached to the device, but the screen is not reading anything. My device is turned on and seems to be functioning otherwise.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
The reading screen is either broken or malfunctioning. You may need to replace the screen. See screen replacement guide here. If this does not seem to fix the problem, you may have an issue with the motherboard. Click here to see how to replace the motherboard.
Immagine Cen-Tech Seven Function Digital Multimeter Mainboard
Guida
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Difficoltà:
Facile
5 - 15 minutes
Immagine Cen-Tech Seven Function Digital Multimeter Screen
Guida
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Difficoltà:
Facile
10 - 15 minutes
Punteggio 0
I'm all for fixing stuff and keeping it working, but Harbor Freight literally gives these meters away. They're not worth fixing. i have a stack of spare ones still in the package waiting to be used.
Punteggio 0
Aggiungi la tua risposta
Anna Kihm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,813
