Salta al contenuto principale
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Cosa ti serve
    1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Position Device: passo 1, immagine 1 di 1
      • Place the meter face down, and the back panel and screws can be seen.
      Chiedi a FixBot
      Aggiungi Commento
    2. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: passo 2, immagine 1 di 2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: passo 2, immagine 2 di 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel: passo 3, immagine 1 di 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Chiedi a FixBot
      Aggiungi Commento
    4. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: passo 4, immagine 1 di 2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: passo 4, immagine 2 di 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Chiedi a FixBot
      Aggiungi Commento
    5. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Motherboard: passo 5, immagine 1 di 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Anna Kihm
Membro da: 10/13/14
965 Reputazione
5 guide realizzate
Clemson, Team 2-4, Benson Fall 2014 Membro di Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Membri
18 guide realizzate
1Commento della guida
What is the little dial on the circuit board on the upper right that has numbers 1 through 3 on it and it can be adjusted thank you
Thomas Clawson - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 39
Tutti i Tempi: 3,205
