Why is my ZTE Telstra T95 not powering on?
After charging my ZTE Telstra T95 about 3 hours, I press the power on button and nothing happens. I tried using a different charger but it will still not power on.
Questa è una buona domanda?
You should first try to plug it in a different outlet. If that does not fix the problem, your battery is probably burned out. You would have to replace it. Check out the troubleshooting page for this device.
My ZTE needs a charge port replaced. I got two estimates and can't afford it. Can you please give me a idea if you can fix it n how much it could cost?
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 171
