Salta al contenuto principale
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127 Domande Visualizza tutte
battery not charging or retainig charge
not charging on severeal hours charger ok lead ok work other devices ? is it the battery or charging port or internal electronics forums donot have answers help
to define cause of problem and resolving it
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
More than likely it is the charging cable. I have had two break. I am currently looking for the pinout for the cable so I can repair the second one.
Philip
EDIT: I have fixed mine. Here are some pictures. The first picture shows the connector upside down compared to the other two pictures. Hope this helps.
Punteggio 0
1 Commento:
Where did you get you cable from?
da
Aggiungi la tua risposta
alex r sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,161
