Salta al contenuto principale
Lightweight cordless vacuum sweeper for picking up crumbs and other small waste.
Why has the SweeperVac lost suction?
The device does not pick up as much debris as it should.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Solution 1:
Air Filter
The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Solution 2:
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Solution 3:
Vacuum Bag
The vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Solution 4:
Vacuum Hose
Remove the hose from the vacuum cleaner, stretch out the hose so that it is straight, shine a bright flashlight into one end of the hose, and look through the opposite end of the hose. If the flashlight beam is not visible from the other end of the vacuum hose, this indicates that the vacuum hose is clogged or obstructed.
Solution 5:
Blower Wheel
Try turning the blower wheel by hand. If the blower wheel does not turn freely, check the wheel for obstructions. If no obstructions are present, the blower motor, not the blower wheel, is likely at fault.
Punteggio 1
The SweeperVac usually loses suction once the dirt bin is full, so all you have to do is empty the dirt bin. However, the filter could also be damaged, in which case you need to replace the filter.
If neither of those are the case, then it is possible that battery has low charge, in which case recharge it.
If none of those work, then maybe the hose is clogged. Remove the dirt bin, and there is an opening to the hose, which should allow you to reach inside with some sort of tool and remove any debris.
Punteggio 0
1 Commento:
I did all of those things and still no suction. Any other suggestions?
da
Aggiungi la tua risposta
Adeoluwa sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 34
Tutti i Tempi: 1,108
