Salta al contenuto principale
Modello A1311 / Metà 2010 / Processore Core i3 da 3,06 e 3,2 GHz o Core i5 da 3,6 GHz
342 Domande Visualizza tutte
Is there a way to to turn an iMac into a monitor?
I have a 21.5" iMac that seemingly has a broken Logic Board. I can hear the fan spin up, and possibly the hard drive or optical drive? I've decided that I don't even really want an iMac, and would like to turn it into a standalone monitor. I understand that I will need a LCD driver board, and I believe I found one for LM215WF3, which is I believe is what I need.
I'm fairly certain I know what to do once I get what I need, but will my driver board going to supply power to my LCD? Is there anything I need to know about doing this? Has anyone else ever done this?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Gary Andrews, this will totally depend on where you get the LCD driver from. Always make sure that you contact the vendor before and clarify those questions. I purchased one (also for a different panel than yours) just to see how it works, check on here. All I needed was a power supply and the results were pretty amazing. Hope this helps, good luck.
Punteggio 3
Aggiungi la tua risposta
Gary Andrews sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 312
