Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
Why is my iPad digitalizer not working?
I decided to replace my iPad screen as my old one was damaged. Everything went well, until I tested it before using the adhesive went back on. Everything's reconnected, and doesn't seem to be damaged. I have checked all the gold pins in the connectors, they're all there! The screen doesn't seem to sense when I'm touching it. I cannot slide to unlock. I don't know what to do now...
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Make sure the digitizer cables are slotted the whole way in it might seem like there pushed in but they could require to have that little bit more movement into the connection..
Take a pic of the cables in the connection and can let you know
Punteggio 0
Take a look at the cable on the screen for any damage, or you can just have a bad digitizer.
Punteggio 0
Aggiungi la tua risposta
Sam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 105
