Salta al contenuto principale
Netbooks need repair too, though they aren't very common these days. Keep yours going with our Netbook repair guides.
503 Domande Visualizza tutte
Screen replacement for Nextbook 8 NX785QC8G
I recently dropped my Nextbook 8 and the Digitizer broke, I need to replace it but I don't know how to take it apart since it has no screws on the outside. I also need a link to a new digitizer screen because I'm not sure as to which one it needs. Thank you for your help!
Questa è una buona domanda?
Punteggio 14
1 Commento
Where can I buy a screen for it
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
You could buy a new digitizer from ebay
New-Digitizer-Touch-Screen-Panel-For-Nex...
Punteggio 3
if you look at the edge of the tablet there's a seam. you want to get a really tiny screwdriver and slow try to open it. when you hear a pop that means the clips on the inside have released and you want to do that all the way around the side of the tablet.
By,Jahn Peabody
Punteggio 2
1 Commento:
After I put it back together the touch screen is not working and it w
as before. No I have not replaced the screen as of yet.
da
I think I'm having the same problem. Dropped my nextbook and it is cracked across the screen. It's crack left to right at the middle of the tablet. I can't use the top portion because the touch screen isn't working on the top. Bellow the crack it's fine. How would I go about replacing it when I get the screen replacement?
Punteggio 1
Yes how much it cost to replace it
Punteggio 0
How to fix the part were the charger goes into the nextbook
Punteggio 0
Aggiungi la tua risposta
Alexander sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 5,747
