Salta al contenuto principale
Netbooks need repair too, though they aren't very common these days. Keep yours going with our Netbook repair guides.
Screen replacement for Nextbook 8 NX785QC8G
I recently dropped my Nextbook 8 and the Digitizer broke, I need to replace it but I don't know how to take it apart since it has no screws on the outside. I also need a link to a new digitizer screen because I'm not sure as to which one it needs. Thank you for your help!
Questa è una buona domanda?
Punteggio 14
1 Commento
Where can I buy a screen for it
da
Aggiungi un commento
5 Risposte
Risposta Più Utile
You could buy a new digitizer from ebay
New-Digitizer-Touch-Screen-Panel-For-Nex...
Punteggio 3
if you look at the edge of the tablet there's a seam. you want to get a really tiny screwdriver and slow try to open it. when you hear a pop that means the clips on the inside have released and you want to do that all the way around the side of the tablet.
By,Jahn Peabody
Punteggio 2
1 Commento:
After I put it back together the touch screen is not working and it w
as before. No I have not replaced the screen as of yet.
da
I think I'm having the same problem. Dropped my nextbook and it is cracked across the screen. It's crack left to right at the middle of the tablet. I can't use the top portion because the touch screen isn't working on the top. Bellow the crack it's fine. How would I go about replacing it when I get the screen replacement?
Punteggio 1
Yes how much it cost to replace it
Punteggio 0
How to fix the part were the charger goes into the nextbook
Punteggio 0
Aggiungi la tua risposta
Alexander sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 5,927
