I am an Apple unauthorised service provider that happened to get one 5s phone with the exact same issues as described here today, and here is how i fixed it.
1: Remove the entire display
2: Reconnect ONLY the ribbon cable with the HOME button
3: Connect the phone to iTunes "used a mac"
4: Push the POWER + HOME for 10 sec or as long is needed to get iTunes to see the phone and wanting to restore it
5: Do a full restore and wait until its all finished.
6: Once done, turn the phone off, and reconnect the screen and all its cables.
7: Turn on the phone, and you should have a working phone again.
Votato
Annulla
Punteggio
3
I think it's a iOS system problem. Maybe you can try this.
How to Fix iPhone Blue Screen of Death
da AshleyBenson
Did u have to buy a new phone or go to a shop and get it fixed there ?
da michallenge ingham
I bought my iPhone 5s last month. After half an hour of consistent usage, it tuned over-heated & turned off & shown blue screen. After turning off for 3 to 4 hours it will be started. Then an alert came on my iPhone 5s about to upgrade to iOS 10, I OK it, then the problem occurred i.e. crashing with a blue screen and then restarting and screen will start flickering, lines were appearing on screen and I will either get a Blue Screen or a White Screen or other different colours. When I turned it on, the iTune logo stucked on the Screen. Then I install the software and tried to Restore iPhone via my PC. All the process went good but at the end of verifying the process, an error would occurred such as the iPhone device could not be connected or could not found. Upon approaching to the mobile technicians regarding fixing the issue, they argued that this is a hardware issue & this issue cannot be fixed in Pakistan. Can anyone help me out in this regard plz.
email: fareedagha48@yahoo.com
Mobile # 0092 3337913627
da Syed Fareed Ullah
I've just experienced this problem now, I've only had my iPhone for 10 months
da khankake1
My iPhone 5s Screen Broke and I had it replace in the mall after it place he hard reset it by pressing the home and lock button so that my touch ID would work The phone work for about five minutes while he was making sure everything worked in the phone turned off and kept restarting and flash the blue screen he then open the The phone and said that it looked like my front camera was old and that he would replace it free of charge because it was working before he touched it no biggie the phone turned back on and has been working since I'm currently using it now but I'm scared to update it because whenever I hard reset it it flashes blue when turning off but it turns back on perfectly with no problems it's only when I press the lock and home button to turn it off does it flash i'm waiting to get a new phone and then I'll update it to see if it stops working but I'm not taking any chances while I don't have another phone
da Kettrick Branch
Mostra altri 3 commenti
