Salta al contenuto principale
Cooler Master's mechanical gaming keyboard. Released with Cherry MX switches.
The light under key cap does not work!
Hello,
I have a problem with the light under the key caps.
Is there any way to replace or fix the light?
Thank you!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes, there is! If the keyboard works as expected, and the only issue is that the light under the key cap isn't turning on, you can replace the LED under the key cap by following this guide. If there are issues with the keyboard other than the light, you can look at the troubleshooting guide.
Punteggio 2
Aggiungi la tua risposta
Sukhyun Baik sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,159
