Salta al contenuto principale
The Nerf Dart Tag Furyfire is a toy gun which fires rubber Nerf darts. It is equipped with a rotating chamber and pump-action barrel for rapid fire.
2 Domande Visualizza tutte
Domanda Chiusa
My pump moves freely?
My pump moves freely and will not catch. How can I fix this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
First, try pulling the trigger. If the gun has already been pumped, it will move freely until the trigger is pulled to release the spring. Then, open the gun using out guide and be sure that the large spring in the top of the gun is attached properly. After that, you can check to see if the pump track has been fractured. Check out our Troubleshooting guide for more details.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 79
