Salta al contenuto principale
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 Domande Visualizza tutte
Domanda Chiusa
Where to find a replacement optical drive
Looks like my drive is broken. I'm looking to replace it. The closest replacement I have found is this drive from SilverStone http://www.amazon.com/SilverStone-SOD01-... and this http://www.madeinchina.com/2722501/S3532...
Is there a better source than these? OWC doesn't seem to have any SATA versions of the optical drive.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
That looks like it's true at the moment, however stock changes so check back some other time and they might have it. However you probably want to get this part soon, so check here, that's probably the second most reliable Mac e-store there is. You'll find links there also on how to install it and videos to guide you, however right here is iFixit's step-by-step installation guide].
Punteggio 0
How about the part from
here? (parts button on the right).
If this answer is acceptable please return and mark it.
Good Luck,
N.
Punteggio 0
1 Commento:
You should double check that link machead
da
Unless I missed it they don't have an optical drive. Just the hd enclosure for the optical drive bay which I already ordered by mistake. I would love it I'd iFixit had the optical drive. Then I could use my credit from te enclosure return.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,445
