Salta al contenuto principale
Miniature one watt version of the classic Marshall half stack. With a tone knob and overdrive channel, it offers portability without sacrificing playability.
7 Domande Visualizza tutte
Micro Amp Battery power not working.
My MS-2R micro amp by Marshall has never failed me in the past but I recently noticed that when I try to use battery power it doesn't work. The wall input works and sounds fine but the battery power doesn't work. I have replaced and used at least 3 different batteries but still no solution.
please help, have a nice day
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Had same problem
I Took the thing apart and there was nothing wrong, I took the wires off the battery contacts and put them directly onto the battery and it worked. So I discovered the problem was the battery wasn't wedged up against the the contacts hard enough. So I cut a piece of card and folded it in half and wedged the battery in there. Switched it on and it started first time, never had a problem since
Punteggio 1
1 Commento:
Ahhh thank you!! This worked for me - I also had looked inside and all wires seemed fine - did as you suggested and bingo!
da
Aggiungi la tua risposta
Jellyfish sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,313
