Salta al contenuto principale
L'Apple Magic Mouse è un mouse multi-touch prodotto e venduto da Apple Inc. È stato annunciato e venduto per la prima volta il 20 ottobre 2009.
Magic mouse looses connection when not moved
Since a few days the mouse is acting weird. When it is not moving the connection will disappear, when the mouse is being moved again it will connect again. Everytime you want to use the mouse it takes a few seconds before it is connected again. Even when you pause 2 secondes to decide where to click on it will loose its connection! This behavior is the same on different MacBooks and Imacs.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Try cleaning both the contacts in the mouse and the batteries. Look for leakage from the batteries. Use a slightly damp cotton swab (Q-Tip) with White Vinigar.
Also try a fresh set of batteries.
Is it any better?
Punteggio 2
2 Commenti:
I tried all of your suggestions, and also the paper trick to make sure the battery's make a connection. But still not working :(
da
You could try opening up the unit and check the solder joints for corrosion. Following this IFIXIT guide: Magic Mouse Teardown. You could just have a bad solder joint as well (battery contacts). Otherwise its time for a new one.
da
Aggiungi la tua risposta
Michael sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 357
