Salta al contenuto principale
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Domande Visualizza tutte
My iPhone wont turn on it is stuck on the apple logo
i dropped my iphone in the toilet and it was working for awhile but then i turned it of to restart it but now it is flashing from the apple logo to black when it is plugged into the chager but when i take it off it goes black again.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The inside of the phone probably has corroded a bit. Over time the corroded components and become more damaged. You would need to take it apart clean it with a toothbrush and rubbing alcohol. See if that fixes it. If not then you can see if one of the parts need to be replaced.
Punteggio 1
need new battery also if its doing boot loop clean it with 70% acohol
Punteggio 0
1 Commento:
use air duster to dry it the reason you use acohol instead of anything else is acohol has a quick drying time
da
Aggiungi la tua risposta
alie123 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,625
