Salta al contenuto principale
Ricevitore GPS TomTom con touchscreen da 5" rilasciato nel 2010.
touch screen doesn't work
Device turns on but I cannot get past the first screen. Light touch, heavy touch, attempting to drag doesn't do it.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
rachel, possibly a bad digitizer. Try to reset your device, to do this, press and hold the On/Off button for 30 seconds and release the button when your device begins to restart. Should that fail, replace the digitizer. Here is a video that shows the display repair, and here how to solder the digitizer if you do it separately. Hope this helps, good luck.
Punteggio 3
2 Commenti:
thanks. I tried press and hold and that didn't work. Will look into a new digitizer. Any idea about the cost?
da
looks like around $10 for the digitizer and $40 for the complete LCD and digitizer.
da
Aggiungi la tua risposta
rachel sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 14
Tutti i Tempi: 7,305
