Salta al contenuto principale
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Domande Visualizza tutte
Do you have to replace the LCD as well as the digitizer?
Just wondering if I have to replace the full LCD and digitizer assembly or can I just replace the digitizer alone? Is it difficult to replace the digitizer alone? Thanks in advance guys :)
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Harry Bouch, unless you have an LCD separating machine and other tools, it will be almost impossible for you to separate those pieces without ruining the LCD. My advice is that you follow this guide and replace the assembly. Not cheap but your rate of success is way higher. Hope this helps, good luck.
Punteggio 1
It's not a digitizer just glass as the touch screen is also the lcd..
You can do glass only but is super super difficult so if attempting glass only be willing to buy a lcd if it goes horribly wrong goodluck
Punteggio 0
1 Commento:
Thank you very much!
da
Aggiungi la tua risposta
Harry Bouch sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 110
