Salta al contenuto principale
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
20 Domande Visualizza tutte
Is it possible to buy the digitizer only?
I have done a lot of glass repairs on s4 but managed to cut the digitizer ribbon in the top left corner on 2 of them, is it possible to buy the digitizer film only? if so where as I can't find anything on eBay. Thanks
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
5 Risposte
Risposta Più Utile
Hi, i know what you mean! I refurbish broken lcd's too and im having the same issue trying to find the digitizer film for a galaxy 3 lcd. Mine didnt even break it just bended a bit when separating the lcd from the mid frameplate. I managed to disconnect the digitizer and reshape the cable but the wires must have broken internally. Its a shame cus the lcd works perfectly. i have honestly tried my best searching with companies from shenzen china that sell laminating equipment and are into industrial repairs but apparently the digitizer film its OEM from samsung. I guess the only option would be to try and remove the film from a broken lcd but its impossible since it warps and bends when heat is applied. Gonna have to go with a new lcd
Punteggio 2
I just checked with my two vendors and neither one sells just the digitizer.
Punteggio 1
4 Commenti:
it's really ridiculous to buy only the digitizer.....lol the front glass cost like 5$ the assembly cost around 100$ .....if you have money to buy the digitizer you will surely have money extra to buy the front glass
da
The reason I need the digitizer film only - I refurb samsungs on a daily basis and I have ripped the Digitizer cable (top left of screen) on x2 s4 lcd's, the lcd's work fine but the touchscreen does not, so I was hoping to get the Digitizer for the lcd's rather than having to throw them away..
da
Only true technicians know what we are talking about lol.
da
Has anyone found anything on how to get it? I've always worked on S4 glass replacements. The one I received was a refurbished one and had the plastic film over the actual LCD
da
Same problem. Samsung guys really make me mad. They are just swindlers and cheaters. Because the digitizer alone may cost some 10 or 15 bucks.
Punteggio 1
why you need to buy the digitizer only? you have two option , first is you buy the whole assembly digitizer+front glass ....or you can buy the glass only . I would advice you to buy the assembly witch cost around 100-159$ available in the store of Ifixit
Punteggio 0
2 Commenti:
da
Also depending on the color of the glass for instance I need just the digitizer for one I'm refurbishin the glass is purple . Now go check price on purple assembly . You can buy a whole new phone for the cost of a purple assembly. RIDICULOUS. ....
da
Hi guys did anyone have any luck getting the ribbons? i have just found a way to remove a working digitaliser from the Top Bezel as my bezel was really worn but in the process i cut the ribbon :-)
Cheers
Punteggio 0
Aggiungi la tua risposta
Kbobble sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,025
