Salta al contenuto principale
Lanciato nel giugno 2009 / processore Core 2 Duo da 2,53 GHz
20 Domande Visualizza tutte
Upgrading ram to 16gb
I have a MacbookPro 5,4 and I have maxed out the ram at 8gb. I am also running OS 10.9.4. Is it possible to upgrade my mac to 16gb of ram? And if so are there any negative effects that this may cause to my macbook pro?
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
2 Risposte
Risposta Più Utile
If this is your machine:
Apple MacBook Pro "Core 2 Duo" 2.53 15" (SD) Specs
Identifiers: Mid-2009 15" - MC118LL/A - MacBookPro5,4 - A1286 - 2324*
It cannot be upgraded past 8 GB of RAM.
Punteggio 7
it depends on your motherboard maximum memory that can handle most MAC before 2012 only can use 8GB
but here's a useful article that might explain things to you
http://www.cnet.com/news/add-16gb-ram-to...
and What you need to know is adding more memory is 100% safe to your system in worst cases your computer won't recognize the extra memory witch means you wasted money for nothing . But you need to know how to do it first because you might harm the mother board if you touch it with static charges
Hope I Helped
Punteggio 0
Aggiungi la tua risposta
William sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 13,271
