Salta al contenuto principale
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Domande Visualizza tutte
Exact Torx Drivers Needed for HD Replacement
The article & video "iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement" answered almost all questions.
Sostituzione disco fisso nell'iMac Intel EMC 2133 o EMC 2210 da 20"
There are several torx styles out there.
Under Tools List at the top: Tools list indicates T6 & T8 drivers needed (which I have).
Under Required Tools at the bottom: Tools list indicates T6 & TR8 needed (I don't have any TR drivers, often referred to as Security Torx).
What exact Torx drivers are really needed. I've found that not everyone realizes all the Torx styles out there, and though standard T drivers will work on Torx Plus applications you can't get a proper torque, TR screws on the other hand have a post in the middle so a standard T driver won't work. See this wiki under variants for clarification...
http://en.wikipedia.org/wiki/Torx
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
I just happened to have a 2007 20" open and tested it out to make sure. It uses a standard T8 bit. I've only seen security torx used on a couple of Mac power supplies.
Punteggio 2
1 Commento:
Thanks Mayer, great news. I know what I'm doing tonight.
da
Hey mate, you don't need a TR8 driver to replace the hard drive, as uses standard T8 screws. It just says that its required at the bottom, as Ifixit recommends you buying a TR8 over a T8 as its more useful and means you only need one screw driver, not two.
Hope this helps
Punteggio 1
1 Commento:
Excellent. I'll get a set of TRs at some point, but for now I'm glad I can proceed. Cheers.
da
Aggiungi la tua risposta
Bryan C sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 168
