Salta al contenuto principale
Apple ha lanciato il MacBook Pro 15" Unibody con un nuovo case in alluminio ricavato lavorando un singolo blocco di metallo.
3092 Domande Visualizza tutte
MBP 15 Display. Voltage not reaching display from board? [with PIC]
I got my Macbook Pro A1286-i7 checked from a Laptop Service Center and the diagnosis report was something like this.
Because of waterlogging the voltage from the logic board is not reaching the display and also the display is damaged.
But I never had any kind of liquid go into my Macbook Pro. It merely fell down from a small height. No damage to the motherboard as the machine works with an external display after the impact but the screen died.
So now I want some advice from the experts here on iFixit.
Can something like this happen?
I am ready to replace the LCD screen but they are also asking me to replace the motherboard which shoots the price of the repair through the roof ($800).
Mind you that the machine works just fine with an external display.
Thinking of buying a LCD screen from and fit it in myself and see if the guys are right about the motherboard.
Kindly help me out on how to go about it.
Update: I also don't see the display listed in the About this Mac => Displays section. [pictures added]. Just the external display. What could have caused this?
[IMG]http://i.imgur.com/WRKoNgh.jpg[/IMG]
Questa è una buona domanda?
Punteggio -1
3 Commenti
Does the backlight work? Does the Apple on the backside glow?
da
nope, it doesn't glow. I think it won't glow unless the display is on (or working).
Am I right?
da
Hello Buco, what do you think? What could be the issue? And what is your suggestion?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds to me like the logic board is fine since it drives an external monitor. What needs to be done is hook up a known working LED screen and see if it works. This can be done by holding the test screen at the correct angle and simply plugging it into the logic board. You do not need to tear the machine down to do this, just unplug the existing cable and plug in the test LCD. Number one find an honest, knowledgeable repair place, the one you went to is not. Where do you live?
Punteggio 1
2 Commenti:
I am from Chennai, India. I also have reasons to doubt those guys. Will the Apple guys replace the LCD panel by removing the glass? I think they might not.
Also there are sites who sell Macbook LCD replacement screens at around 60 dollars where they also teach how to replace the screen using a heat gun and a suction cup. Do you think it would be wise to follow that path. Many have done so as per their testimonial section.
da
Hello Mr.Mayer what do you think? Have added a picture. Kindly have a look.
da
Aggiungi la tua risposta
iDev sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 143
