Salta al contenuto principale
The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Can I upgrade from 4GB to 8GB RAM memory?
I have a MacBook Air 11" mid 2013 that came with 4GB RAM and 128GB hard drive. I want to upgrade the RAM to 8GB so I can run Vmware more efficiently with windows 8.1 and other software that don't run on the mac-side.
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sadly, no
Apple soldered the RAM to the logic board. You can upgrade the SSD! It's replaceable.
Punteggio 5
2 Commenti:
Could you replace the entire logic board with one that had 8gb of RAM rather than the original 4gb?
da
Swapping out the logic board with one that has 8 GB of RAM is possible!
But, the cost factor for doing this then becomes the issue. I would recommend locating a used system which is newer as being a better investment.
da
Aggiungi la tua risposta
Rich sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 5,005
