Salta al contenuto principale
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Domande Visualizza tutte
After home button repair, unresponsive touch screen
I replaced the home button & cable on a Sprint iPhone 4. Everything went fine, I didn't run into any obvious issues. After reassembly/connecting the battery, the phone turned on. The locked home screen appears when it's plugged in to a power source, but the home button is unresponsive and the touch screen is unresponsive. So I'm stuck, not sure what to check for on this one.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Open phone again and make sure the connections are seeded on the lcd and digitizer if they are and still unresponsive touch you have damaged it make sure you didn't crimp the digitizer cable against frame when reinstalling ..
As for the home button make sure you have the little latch pushed down or it could be just a faulty button flex
Punteggio 1
Aggiungi la tua risposta
MargotJoniec sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 194
