My mobile is get soaked with water,motherboard is flushed wit water!
my mobile is get soaked with water,motherboard is flushed wit water! my mobile screens touch panel keys are not working!
Questa è una buona domanda?
pydah santosh, the very first thing you want to do is to not try to restart the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using then clean it with +90% isopropyl alcohol. Follow this guide, and even so it was written for a 3G all the points are still pertinent to your phone. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. It is possible that it is "only" your digitizer that may have failed, but it is also possible that you are having touchscreen IC problems. While you clean your board, check for any obvious damage, like burned or missing components etc. If there is no change you could start by replacing the front assembly. Hope this helps, good luck.
i too recently faced the same problem.
unfortunately my digitizer was okay but my motherboard was blown.
you cannot have another motherboard, as it has IMEI number on it.
nokia doesnt sell it loose, or may be the cost is too much that you can get a new phone..!!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 613
