Salta al contenuto principale
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Domande Visualizza tutte
Domanda Chiusa
Display problem after installing optibay
Hi Experts,
After following the DIY for installing Optibay with an SSD which went fine, i got problems with the LCD.
After reassembling everything and starting the display was a little pinky and have noise like an old TV.
During the installation and reassebly I've checked all cables and connections carefully. Everything looks fine.
Please help!
Thank you in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like your GPU has a problem. Did you use proper ESD precautions? Have you tried connecting an external monitor to your system to see if it too is effected?
In the meantime you could try resetting the NVRAM as well as try running AHT. Here's a Apple TN that will guide you for both: Startup key combinations for Intel-based Macs.
Punteggio 1
1 Commento:
Hi! NVRAM reset helped! Thank you for the hint.
da
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 110
