Why is my Gateway MA6 Laptop overheating?
My computer quickly overheats under normal usage, and prompts me to turn the computer off until it cools down.
Questa è una buona domanda?
You're cooling fan assembly is mostly likely either clogged, or faulty, which is limiting your computers ability to dissipate heat and run at a reasonable and stable temperature. Replacing or cleaning out the cooling fan will help. You can reference the Cooling Fan Assembly Replacement Guide here for instruction.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 361
