Salta al contenuto principale
Gateway MA6 Laptop Cooling Assembly Replacement
Cosa ti serve
  1. Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: passo 1, immagine 1 di 2 Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: passo 1, immagine 2 di 2
    • Loosen the seven 6 mm Phillips #0 screws on the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  2. Gateway MA6 Laptop Cooling Assembly Replacement: passo 2, immagine 1 di 2 Gateway MA6 Laptop Cooling Assembly Replacement: passo 2, immagine 2 di 2
    • Pull upwards on the top of the back cover to remove it.
  3. Gateway MA6 Laptop Cooling Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the four 9 mm Phillips #0 screws from the cooling assembly.
  4. Gateway MA6 Laptop Cooling Assembly Replacement: passo 4, immagine 1 di 3 Gateway MA6 Laptop Cooling Assembly Replacement: passo 4, immagine 2 di 3 Gateway MA6 Laptop Cooling Assembly Replacement: passo 4, immagine 3 di 3
    • Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer.
    • Gently flip the cooling fan assembly upside-down on the computer surface.
    • Carefully grab the wire attached to the computer and pull away from the port.
    • The cooling fan is now safe for removal.
  5. Gateway MA6 Laptop Cooling Assembly Replacement: passo 5, immagine 1 di 1
    • When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
    • If your unfamiliar with applying thermal paste Come applicare la Pasta Termica
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 6-2, Forte Spring 2014 Membro di Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 784
