Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Overheating motherboard No Display and Computer wont recognize
Hey guys, I appreciate all you do and thanks for taking the time to read.
I have two iPhone 4S motherboards that wont boot, or be recognized by any computer, But they do start to heat up once plugged into the computer or power source. The section of the MoBo that heats up is just above where the charger port flex cable plugs in (I believe its the heatsink fan-ish area) heats up slowly but very noticeably hot.
History- the first iphone 4s was slammed against the corner or a desk bent to heck. After i replaced the display the device turned on and worked perfectly....
To try and save a few bucks I disassembled all the parts, carefully taped down the flex ribbon that's adhered to the bezel, wrapped in 1 layer of bubble wrap and used a rubber mallet along the edge of the frame to straighten it out.
Checked all cables for damage then re-assembled iphone and...... Nothing. Just heat, no display nor will any computer detect it
I even went as far as to switch motherboards with another 4s that was working perfectly, once i traded MoBo's.... Nothing.
So i dont think i caused any damage to the flex cables during my highly technical and complicated procedure of hammering the frame with a mallet.... lol
Any Ideas guys???????
Questa è una buona domanda?
Punteggio 0
1 Commento
Have you looked over all parts to ensure solder wasn't damaged or parts were damaged in the process?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
you removed the logic board before hammering the frame, correct?
If this is the case---you had a known good logic board which you removed and did some messing around with the frame--and now the logic board gets hot.
If you hammered the phone with the board in place then = drop damage, you'll need a bga reball of some chip, forget it.
If not, then:
1.) You damaged the board when pulling it out.
2.) You damaged one of the flexes while hammering.
Solution: try to start the board with nothing connected except a battery, LCD, and power flex. see what happens and report back.
Punteggio 2
Aggiungi la tua risposta
uccstore sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,069
