Salta al contenuto principale
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Domande Visualizza tutte
Domanda Chiusa
touch screen non responsive
Yesterday i was replacing the glass on my galaxy s3 and the phone fell out of my hand and fell about foot from the ground. when the phone fell is did have the broken glass on it and i was in the process of replacing the screen. when i picked up the phone it was fine but one of the screws on the left side of the battery had fallen out. i continued replacing the screen and got all done and the phone powered on perfectly but the touch screen wasn't working. Everything on the phone works fine all the buttons and even the screen rotates. The touch screen is non responsive. I tried couple things already taking the phone apart and cleaning the cable for digitizer. and placed the cable back one, nothing changed. Please help, i really dont have enough to buy a digitizer. Thnak you!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Did you remove the glass only? If so the SMALLEST nic on the side of the digitizer (which can be nearly impossible to see) can cause it to no longer function. I've made this boo boo before and have never tried going at the glass from the side since. The only way to test this is to plug a new full front/working digitizer into the phone and see if it works. If it does then you nicked the digitizer. If not, then something happened to the board on the drop. Unfortunately neither outcome is very good :-(
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 379
