Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Domande Visualizza tutte
Domanda Chiusa
I hear a click as if the adhesive did jack and then let go
after about two months that I glued the glass ipad 3 if I press strong in some points of the frame I hear a click as if the adhesive did jack and then let go ... I can feel comfortable or do I take off again and add the glue? in which case glue can I use? thanks (I state that the glass does not seem relieved than the small plastic seal "bezel")
Questa è una buona domanda?
Punteggio 0
1 Commento:
Thanks for the reply Joshua, I'm sure that the 'LCD is fully assembled. I'm a fairly accurate and this will be at least one twentieth ipad dismount, only just a few times the digitizer does not adhere perfectly right .. of course you have to press very very strong to notice the problem, and I realize that the aftermarket will not be as double-sided the original apple ... but I was wondering why ... andrea
da
Aggiungi un commento
1 Risposta
It sounds like the glass/digitizer is being held up by the LCD not being properly mounted. I think you need to disassemble the device and check for proper fit of the components. You may need to remove the adhesive and then add new adhesive strips to ensure proper bonding and fit.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 84
