Salta al contenuto principale
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Domande Visualizza tutte
My ipads wifi is greyed out but bluetooth still works?
hi there i have problem with my ipad 2 after screen replacement/ i think the wifi board has been damaged. what will i need to change to get this fixed? the whole wifi board or just a chip on it? and can you give me a link where i could buy it from thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
I would start by replacing the wi-fi/bluetooth antenna. Both antennas are part of the same component. They are EXTREMELY easy to damage during disassembly for replacing the digitizer or any other internal component. You can purchase the antenna here and then follow this guide.
Update
Yes, replacing the wi-fi board would be my next step. The only source that I've found for them is eBay.
Update
Yes, I believe that's the one you need.
Punteggio 0
2 Commenti:
hi jousha, well i just have replaced the antenna but no luck, i think the wifi board needs replacing?
da
By iPhone 3g/gs (I hope that similar is on iPod) is important that the screw on mjute holder catches the flat cable to the frame of the phone to the antenna had grounding. If the screw is not well tight Wi-Fi will not work.
Punteggio 0
Yes I would try the wifi ant, make sure you don't buy the board. That is hidden and rarely is the cause of the problem. To replace the wifi it requires removing 4 screws and connecting the wifi into the area next to the board. Super easy!
Punteggio 0
1 Commento:
I have replaced the wifi antenna on a1395 and still the wifi is greyed out and Bluetooth is not working as well. What should I do next??
da
Aggiungi la tua risposta
momomomo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,908
