Salta al contenuto principale
Informazioni e guide di riparazione per i modelli MacBook Pro con display da 13".
compatible LCD display between A1278 and A1181 MacBook?
I have been offered a A1181 Macbook for lifting the LCD-panel – not the assembly — and I need this to be compatible to connect with the cables in the A1278 and otherwise work fine. These models have the same graphic card and the same resolution and are quite similar. Are there any reasons the LCD from the A1181 wouldn't work in the A1278?
A1278: Specific machine at everymac
A1181: Specific machine at everymac
Questa è una buona domanda?
Punteggio 1
5 Commenti
In order to give you the proper answer, you would have to post the last three digits of the serial numbers for the A1278 and the A1181. Once we know for sure which models you have, then we could tell you more about compatibility
da
As you can see in the goo.gl links the A1278 is the 'MacBook "Core 2 Duo" 2.0 13" (Unibody)', Identifiers: Late 2008 Aluminum - MB466LL/A - MacBook5,1 and the A1181 is the 'MacBook "Core 2 Duo" 2.0 13" (White-09), Identifiers: Early 2009 - MB881LL/A - MacBook5,2.
da
Updated with proper links. Sorry.
da
As you already found out, the complete assembly will not fit. You want to get the serial/model or manufacturers numbers of both LCD's and post them on here. That way we could try and look a bit deeper for a proper answer.
da
Given I can get these numbers, what factors would indicate the LCD-panels are not interchangeable? The connectors and cables to the display would be one obvious obstacle. Are there more known incompatibility factors?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The parts catalogue says 09's fit 09 & 10 - not earlier models.
If this answer is acceptable please remember to return and mark it.
Immagine Replace a display compatible with the model A1278 Mid 2009 to Mid 2010 Unibody MacBook Pro 13" laptop. Part #661-5232, 661-5558. Includes the 1280 x 800 13.3" LCD screen, display cover, bezel, iSight camera, clutch hinges, display inverter, Wi-Fi antenna, and display data cables.
Prodotto
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Display Assembly
$249.99
Punteggio 1
1 Commento:
Yes, thank you but my question is not regarding the display assembly, but about the LCD itself.
da
Aggiungi la tua risposta
MiB sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,252
