Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
White Screens after Battery Replacement
I ordered the battery replacement kit followed the instructions to a T and I ran into a screen issue. At first I had small white rectangles at the very top of the screen. I tried power cycling, disconnected and reconnected and the problem still persists.
After reconnecting however the lines have changed size and are now full length of the screen from top to bottom. I have tried connected over and over but I have yet to find a solution.
Someone please offer some insight.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Mark worst advice ever!!
Punteggio 1
3 Commenti:
No... it works... we are fixing iphone 5 everyday and have the white stripes every time. And they disappear after a few hours using the LCD...
da
I ended up restoring my phone to get rid of the lines completely. Everything appears to be working find now!
Thanks!
da
how did you restore your iphone?
da
Hi,
close the iphone and let the lcd running for a few hours. The white rectangles will disappear within a day
Punteggio 0
You can also try cleaning the contacts, and make sure then are seated into the logic board.
Punteggio 0
Aggiungi la tua risposta
jacobtshaw sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 748
