Salta al contenuto principale
electric dryer wont start and led lights are on
maytag electric dryer wont start when switch is pushed but all lights are on
Questa è una buona domanda?
Punteggio 34
21 Commenti
What model is your dryer?
da
MY gas dry model number NGD7200TW
da
I am trying to fix this issue right now it's a pain in my behind and I'm not getting anywhere. And suggestions?
da
I have a samsung front loaded it has power to the panel but won't start
da
Had lightning hit close to house last night and now panel comes on but dryer won't start. Maytag Bravos
da
Mostra altri 16 commenti
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Thermal Fuse
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Start Switch
The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Most door switches will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Picture Unavailable
Drive Motor
On most dryers the drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt
On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit
Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Other Causes and Conditions
Incoming Power Problem
If the dryer won't start, check to make certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch
If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board
The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer
The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Punteggio 10
11 Commenti:
I used the continuity checker to check the timer where lot of cables are connected to. I found 2 of cables have no power, and I thought the timer is defected. I checked the 2 fuses and thermal element are fine. Please help. Thanks.
da
Lienvu as this question is old you might want to ask your own and give exact specifics. I have no idea of which cables you are checking, some are ground and do not carry current at times.
da
If the Thermal Fuse has blown would the lights still come on on the dryer. I put the clothes in the dryer, all the lights come on but the start does not work - just a click sound from inside the dryer. Maytag YMEDB400VQ0
da
All the lights come on. But it won't start. Checked motor switch, motor, thermo fuses for continuity or resistance but all check out. There is a clicking noise coming from top rear section of dryer when I attempt to start. Is there a way to check the board? Charlie
da
I am having the same issue with my electric maytag model MED9600SQ0 dryer. Press start, hear a clicking sound & sensing light comes on but no action.
da
Mostra altri 6 commenti
I have the Bravos model. Same symptoms as listed above. Checked all possible sensors. Still wouldn't run. Opened up control panel and removed the circuit board. There was an obvious burn spot on the inside of the plastic housing where the circuit board sits. The burn spot lined up with a relay. Tested the relay with ohms meter and determined it was failing. Googled the # on the relay and found it online for $3. Yes. THREE DOLLARS. Swapped relays, and dryer is fine. GLAD I DIDN'T HAVE TO PURCHASE THE WHOLE BOARD!!! hope this helps someone else.
Punteggio 4
6 Commenti:
How did you access the board please step by step if posible
da
Unplug dyrer from power source .Remove two Phillips screws at back of console. Turn over console as needed to unplug all wire connectors.(another set of hands helps) . The circuit board sits in a box, which slides into a holder. The box is removed by sliding it one way or the other to release two plastic tabs (seen from standing behind the dryer) from the holder. Once box is removed, open it, and gently remove circuit board. I was able to see the burn spot, and align it with a relay.
Take your time, and good luck!
da
we have replaced about 5 thermal fuses. they keep blowing out. called out a service man he said it was the relay will cost about 248.00 plus a new thermal fuse and another service call. about 400.00. well now iam wondering if its what trouble you had. we have a bravos dryer also
da
You have an air restriction problem. The dryer isn't letting heat escape. Check your vent line and hose. When heat builds up in the dryer,it blows the thermal fuse to protect it.
da
@lawson913 The service man SHOULD have checked the vent for lint and blockage when he replaced the fuse. That's common practice.
da
Mostra 1 altro commento
Aggiungi la tua risposta
ljslsr sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 316
Tutti i Tempi: 265,426
