Salta al contenuto principale
Modello A1311 / FIne 2009 / processore Core 2 Duo 3.06 o 3.33 GHz
310 Domande Visualizza tutte
Install SSD, 3 answer
Hi all, thank you first for reading and maybe replying my answer (wtf my english, sorry).
I know i could search on the web, but on it i couldn't find all I needed. I'm here because I need to replace my HDD with an SSD. I didn't understand 3 thing:
1) I have a SATA 2 on my iMac and the SSD is SATA 3. Ofc I'll lose performance, so... Can I do something to resolve that? (Change my iMac SATA maybe?)
2) My iMac will not be filled up, so I can put my SSD as first and only HD. Is that ok? Can I do that? (Or it's better to put it together my default HHD [it's called fusion drive right?])
3) I read that to put my SSD I need at all cost to remove my SuperDrive (CD and DVD drive) and then but a support, is that right?
I know, a lot of answer, but I say thank you a lot if u can reply completely.
Ty for your time and patience again.
BB - Alberto
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You can not change the SATA speed on your machine - it's a function of the bus. Some sATA III drives play quite well at lower speed (they are "self-limiting" and virtually transparent to the user) others have to be manually set to lower speed (do some research - see links below).
As for your proposal see this and this previous answers to the same question.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Aggiungi la tua risposta
albertobagnacani sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 475
