Salta al contenuto principale
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 Domande Visualizza tutte
battery physical size (in relation with LG G2)
Hi,
may you confirm the physical size of the Nexus 5 is identical to this one of the LG G2?
Is it technically possible to buy the silicon battery of the G2 (3000mah) and install it in the N5 (same connector, same voltage aso)?
Questa è una buona domanda?
Punteggio 4
2 Commenti
I'm also looking for an answer to this as I'm looking to purchase this-->http://www.smavtronics.com/3000mah-bl-t7...
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
I4U, no you can not. The batteriy are different sizes
LG G2 BL-T7 size 55mm wide X 67mm long
Nexus 5 BL-T9 size 57mm wideX 60mm long
and the battery cable is on a different position.
Punteggio 3
I don't know about the physical size but looking at the LG G2 user teardown and the Nexus 5 featured teardown:
  • Nexus 5 battery reference is BL-T9
  • LG G2 battery reference is BL-T7
  • mAh's are different
  • Finally the battery connectors looks not at the same places
I think we can conclude that you can't install a G2 battery on a Nexus 5, sorry. However, there is Nexus 5 batteries available on internet. Look for "LG BL-T9" on google and don't miss the Nexus 5 Battery Replacement guide on iFixit.
Immagine Nexus 5
Guida
Smontaggio Nexus 5
Difficoltà:
Moderato
Immagine LG G2
Guida
LG G2 Teardown
Difficoltà:
Moderato
30 minutes - 1 hour
Immagine Nexus 5 Batteria
Guida
Sostituzione batteria Nexus 5
Difficoltà:
Moderato
20 - 40 minutes
Punteggio 1
the size seems to be different
Punteggio 0
Aggiungi la tua risposta
I4U sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 6,257
