Salta al contenuto principale
Ricevitore audio video home theater Denon AVR-391. Si tratta di un ricevitore home theater di fascia entry-level.
Why does the receiver turn off after pushing the power button on?
So when I turn on my Receiver from Standby mode it briefly powers on then makes a signal noise error like you are watching static television then the Receiver turns off and a Red Ring flashes around the Power button. I have tried opening the tv hutch door where the Receiver is at to give it more ventilation because I think that could be a possible culprit. Does anyone know anything specific to this brand or model?
Denon AVR391
Questa è una buona domanda?
Punteggio 4
4 Commenti
When I turn on my receiver it lights up then goes out
da
Can it b a fuse
da
It can be a speaker wire connection, pull one wire at a time while switching the unit on and off.
da
No speakers hooked to mine and it still do it
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Sounds like the unit is going into protect mode. There are a few causes for this. First unhook all the speaker connections. If it stops doing it then, there must have been a short in your speaker cables or speakers. If it continues to go into protect mode you either have a blown power amp or blown power supply(maybe a bad digital boards, but thats highly unlikely). That will have to be serviced by a professional. If the unit was not receiving proper ventilation to begin with chances are it overheated and it caused the current failure. Sorry to hear about your issues, I hope you fix them.
Punteggio 4
3 Commenti:
I have two radios they both were in storage for 5 years now both don't work power on for 2-3 seconds then turns off.
da
how can i fix it my self
da
My zenon plays for a minute then shuts down with a red light around the on off switch
da
Aggiungi la tua risposta
Nephew sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 43
Tutti i Tempi: 24,823
