Salta al contenuto principale
Repair and disassembly guides for Apple Time Capsule wireless network devices.
147 Domande Visualizza tutte
Can I use a 2 TB drive to replace a 1TB
I have a first generation Time Capsule, version 6,106. The drive seems to have gone bad and I'd like to replace it. Does anyone know if I can upgrade the drive to a 2 TB capacity rather than the 1 TB that it shipped with?
Many thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes, it can be done!
A 2 or 3 TB WD Green drive should be just fine here. I would recommend opening the fans venting a bit. You will use the AirPort configuration tool to prep the drive (it does not use either a Mac or Windows file system).
Punteggio 3
2 Commenti:
Dan, thanks very much for the information. I removed the drive (an Hitachi Drivestar) that I tested with Drive Genius. It's got some serious bad blocks that stop the test in it's tracks.
I decided to not replace the drive at all and use the unit as an Airport Express. My backup strategy is more centered around Carbon Copy Cloner with USB-attached drives. I don't like using Time Capsule for my MBP as it's slow over wireless.
I was a bit surprised to find that the unit will operate without a drive, but so far, so good. If I change my mind in the future, I still have the option to add back the drive.
Again, many thanks for your answer!
da
If this answer answered your question please remember to score it and mark it accepted.
da
Aggiungi la tua risposta
Ron Lockhart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 164
