Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Domanda Chiusa
Lock Button slowly not responding
The Lock Button on my iPhone 5 is starting to slowly not response when I push it. I've read it's due to manufacturing defect. Unfortunately, I'm guessing my phone is now past the limited warranty period (which I'm confirming on Monday.)
My question is can it be repaired using the iPhone 5 Power Button Replacement Guide or not?
Thanks!
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks, Tom Chai. I completed the "Audio Control and Power Button Cable" guide and it solved my problem. See: Sostituzione controllo audio e cavo pulsante accensione dell'iPhone 5
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
No. The correct one is "Audio Control and Power Button Cable". The power button is just a piece of metal that pushes the actual switch underneath it.
Punteggio 1
trocar o midi flex do botão de bloqueio de seu iPhone 5
Punteggio 0
I have to depress the power/lock button on my iPhone 5 at the far left to make it connect. Do you think a new cable is needed or should I try to run through the steps of replacing the plastic button to see if there is any dirt preventing a solid connection?
Thanks!
Punteggio 0
2 Commenti:
new cable will solve the problem. apple made a low quality cable on this phone. very common issue
da
Thanks Vlad, I'll give this repair a shot.
da
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,323
