MacBook Pro Disk Drive is not working
My MacBook Pro accidently took a tumble the other day, and now the cd drive won't read cd's. How much would it cost to fix/repair this problem?
Questa è una buona domanda?
Run Applications->Utilities->System Profiler look under ATA devices. Verify the divice is listed. If it is not the cable is disconnected, damaged or the device may be damaged, only further examination can provide a solution.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 13,517
1 Commento
Need the exact model of your MacBook Pro and size to give you the right directions and part. If the battery is removable on your model, that it out and get the information from inside the compartment
da mayer
