Salta al contenuto principale
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
Can I put a Seagate SSHD in my iMac?
I hope to soon upgrade the 320GB HDD in my Mid 2009 iMac to a more roomy 2TB drive. I have looked at 2TB HDDs like this Seagate one, but was wondering if the 2TB Seagate Hybrid Drive is worth the extra $40.
I know it would be faster, obviously, but would it work with my iMac? And is it substantially faster than just an HDD?
Right now my iMac takes over 1 minute to start up, and then over 1 1/2 minutes after logging in to load all the startup items.
Thanks for the help!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I do think the extra for a hybrid drive is worth it. In your case you can't add a second drive via SATA so this is your best option.
The only thing you do need to watch out for is SATA I/O speed. Your systems SATA I/O is SATA II (3 Gb/s) This HD offers compatibility across SATA I (1.5 Gb/s), II (3.0 Gb/s) & III (6.0 Gb/s) others might not play well (in case you change your choice).
Go for it! you'll be happy with the speed improvements.
Punteggio 2
3 Commenti:
Awesome! Thanks! I'll consider it! I already knew about the SATA speeds, and that my system won't take advantage of all the speed it could, but thanks for the info.
da
Hi, I just bought one of these of IFIXIT but the drive does not show up in the boot Menu. iMac 27", early 2009 (?).
Reading the internet I guess the problem is the SATA speed. Can I reduce it via jumpers ?
da
@Arne - Can you please identify which drive you got. Did you partition & format the drive with Disk Utility? The drive won't show up until you have prepped it.
da
Aggiungi la tua risposta
Evan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,199
