Salta al contenuto principale
How to open g4 a1104 case
How to open case after removing all screws how to seperate top from bottom with out breaking, any ideas other than just sticking a card into it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here's the guide on how to tear it down, just carefully follow it: PowerBook G4 Aluminum 12" 1-1.5 GHz Logic Board Replacement
Punteggio 2
1 Commento:
follow the guide +
da
If you're certain that you removed all the screws take something like a creditcard or a similar stiff piece of plastic an carefully lever it in the gap between top and bottom case. Be espacially careful around the optical drive slot.
Punteggio 1
Aggiungi la tua risposta
jonathan Williams sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,132
