Salta al contenuto principale
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
126 Domande Visualizza tutte
Display - Screen colors go fussy
The display screen on my Samsung Galaxy Note 10.0 note goes fussy and the screen does not always respond to touch. I don't know if it is the screen only or the digitizer. The tulips are my screensaver and what happens is that the edges of the tulips start becoming fussy and the colors start changing. Please let me know whether I should buy a new digitizer and if so please let me know how to install it.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
That sounds like the LCD. The digitizer wouldn't change any coloration. Also take in to consideration if you left this device in the direct sun for a long time or in a vehicle it may be a GPU overheating issue. If not. I'd say LCD. Just my opinion. Good luck.
Punteggio 0
3 Commenti:
I had this same problem of fussy colors. I left it in my car facing the dun for long. How do I get my right colors back?
da
I need advice for my samsung note 10.1. Mostly fuzzy screen and blue shadding around pictures. My blue screen for the signing in to samsung is now green.
da
I am having similar problem as the last comment with my Note 10.1. The screen is mostly fuzzy with a royal blue color around pictures/objects on the screen. Can this be repaired? Grandma Sil
da
I faced the same problem before. I sent it for repair and the technician said it was due to a flex cable problem.
After replacement, it can be used as normal.
Punteggio 0
Aggiungi la tua risposta
Julie Dobbs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,297
