Salta al contenuto principale
Tutto quello che ti serve per riparare stesso il tuo iPhone! Dal nuovissimo iPhone 15, fino all'iPhone 2G originale del 2007, iFixit offre guide di riparazione gratuite e informazioni sullo smontaggio per ciascun modello di iPhone, oltre a fornire le migliori parti di ricambio, strumenti e consigli della galassia.
36472 Domande Visualizza tutte
I get "Charging is not supported by this device" w/nothing attached
Contaminated my iPhone 3GS with a mixture of oil, sugar, soy sauce. (Korean BBQ Marinade)
Not much but just enough to cause the message "Charging is not supported by this device" when ever I wake the phone from sleep.
Everything seems to work and it will charge. The message goes away when the docking cable is attached.
What do I do as the Apple "Genius" told me I'm sol unless I want to pay full freight on a new phone.
Questa è una buona domanda?
Punteggio 1
5 Commenti
Thank you markus, after a bit of scrubbing with a brush and alcohol I am alert free. No disassemble required.
da
Can you accept his answers? Then he'll get credit :)
da
hi david,
great that it worked for you
²chris - yeah - would be a good idea - but the important part was that it worked
da
LOL, it's not just for credit, we do a lot of backend things based on "accepted" answers. When good questions like this get good answers I try to push to make sure the right answer gets accepted.
da
Ok, I liked the answer because it fit with my theory of what could be causing the problem. Technically it didn't "fix it" per say, but improved the situation to where I only get transitory messages telling me I have an unsupported device attached where before it was when ever I woke the phone from sleep. A tear-down and through cleaning would probably cure it, but I don't trust myself not to break a known good component in the process.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
here is the guide to get the logicboard out
my magic glass orb told me that there is a shorted connection around the dock connector.
serious - the fluid has shorted something in the charging part of the phone, it ould be that is outside on the contacts of the dock connector - look closely, use rubbing alcohol and a soft brush to clean that area carefully - if there is nothing on the outside, it's inside the phone - but i'm pretty shure about the dock connector
if you see something slightly white/greenish (almost likt mold) - thats it - if you are lukcy - you don't have to replace anything - but be careful whith the disassembling
Punteggio 2
Aggiungi la tua risposta
David Nakase sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 8,573
