Salta al contenuto principale
Repair guides and support for external portable storage by Western Digital including the My Book series, My Passport and others.
218 Domande Visualizza tutte
Domanda Chiusa
external hard drive western digital wd5000bmvu ports info needed?
Hello,
I have an external hard drive western digital WD5000ME that no longer works.
It starts (the LED Alume and blinking, the drive seems to run), but the connection to the PC does not work (or whatever the PC operating system).
I dismounted and have extracted the hard drive to connect it to my motherboard directly.
I then discovered a hard drive (reference wd5000bmvu) with 2 connectors:
- The USB connector (the one that was accessible from the outside) soldered on the printed card hard drive
- The simple pine: only 1 left, a series of six in the middle and two on the right.
Not knowing this second connection (it is obviously no SATA or micro SATA), I used the wisest of you to enlighten me
on:
- The name of this connection?
- Where to find an adapter / cable?
- Other methods to try to recover the data (before sending it to someone whose job it is ...)?
Thank you in advance!
Update
Hi ,
Guys thanks for the answers till now , i am adding the picture of the pins attached to the western digital external hard disk for which i need the information for.
Questa è una buona domanda?
Punteggio -1
2 Commenti
All info I can find states it is a SATA drive. Can you upload a picture of the connection to help us?
da
VGO, WD said, quote, "This is not a connection we provide support for. It is there for data recovery companies to recover data in emergency cases. We do not have any schematics regarding the pinout of the 12 pins, again, this is only for data recovery companies who plug their special connection to recover data." take a look on here
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here;s some very good info on this drive: My Passport WD External HD fails to mount to desktop
Punteggio 2
2 Commenti:
Hi mayer , thanks for the link .
But being a novice i was still unable to understand the use of 1 + 6 + 2 pins on the front side of the hard drive alongside micro USB point.
Could you please let me know the use of the same.
da
Very useful answer mayer--thanks and good to see you online again. +
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 8,971
