Salta al contenuto principale
Repair guides for cameras by the Japanese manufacturer Fujifilm.
20 Domande Visualizza tutte
Will not power on
Camera in mint condition but out of warranty. Tried different sets of batteries but still will not power on. Any help would be appreciated.
Thanks
Chris Hogg
lcehogg@o2.co.uk
Questa è una buona domanda?
Punteggio 1
1 Commento
same problem....
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
See this procedure i made for repair of the command dial of the Fuji S9000 (i think it is similar to Finepix S9600) . may be helpfull to you .
http://www.flickr.com/photos/jgustavoam/...
Punteggio 1
Hello,
I have exactly the same problem. In my case the cause is a switch on the circuit board that is responsible for the switching on and off which is broken. The switch itself should be quite cheap but I am not electrical engineer and I have no idea how exactly this switch is called or from where it can be ordered.
Punteggio 0
Punteggio 0
I had a situation where, with known good batteries, the camera would act like it wanted to turn on and I would get the welcome cheep... but that was all. Only by opening battery door and re closing could I even get that much again. It turned out to be a faulty SD card. I pulled the SD memory card out, and presto, it came back to life. I would rather buy a new SD card than a camera!
Fuji fine pix s9200 with a LOT of miles, ( I am a news photographer) "What matters more than every other thing: Get the %#*@ shot!"
3 minutes ago by Chris Mills
Punteggio 0
Aggiungi la tua risposta
Chris Hogg sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 72
Tutti i Tempi: 12,274
